PCM-Portugal - A Comunidade Lusófona de Ciclismo e Pro Cycling Manager https://www.pcm-portugal.com/forum/ |
[PCM14] A.S.O.DB 2014 https://www.pcm-portugal.com/forum/viewtopic.php?f=229&t=9138 |
Página 1 de 1 |
Autor: | OlegTinkov [ 04 Ago 2014, 16:50 ] |
Assunto da Mensagem: | [PCM14] A.S.O.DB 2014 |
Simply the Best A. Install Pro Cycling Manager 2014 + Latest Patch B. Open Pro Cycling Manager 2014 and closed it (this will create the Pro Cycling Manager 2014 folder in your documents). Citar: 1a. Download the A.S.O. DB 2014 Stages Pack 2a. Unpack the PCM14ASODB2014Stages.rar on your desktop. 3a. Copy the CM_Stages folder and paste (merge/overwrite) it in the folder where you have installed Pro Cycling Manager 2014 (usually C:\Program Files\Cyanide\Pro Cycling Manager - Season 2014). Citar: 1b. Download the A.S.O. DB 2014 2b. Unpack the PCM14ASODB2014.rar on your desktop. 3b. Copy the 8 folders (from 3D to Xml) and paste (merge/overwrite) it in the folder where you have installed Pro Cycling Manager 2014 (usually C:\Program Files\Cyanide\Pro Cycling Manager - Season 2014). 4b. Copy the ASODB2014.cdb to -> C:\Users\YourName\Documents\Pro Cycling Manager 2014\Mod\Database. 5b. Copy the top_giro.xml and top_tdf.xml to -> C:\Users\YourName\Documents\Pro Cycling Manager 2014\Users\*YourUserName*\Import. 6b. Start Pro Cycling Manager 2014 and choose the ASODB14.cdb @ Database/Options, also check if "Rider faces" is turned on @ Graphics/Options. All other options are personal preferences, that you can customize. UCI Teams (click to enlarge) WorldTour Teams (click to enlarge) Professional Continental Teams (click to enlarge) Custom Teams (click to enlarge) Equipment Exclusive A.S.O.DB 2014 Equipment for all teams (click to enlarge) Stats (click to enlarge) Track Equipment (click to enlarge) Matrix Stages and many more (+2000 Stages) Credits OLEGTINKOV (All files made by OlegTinkov are exclusively made for the A.S.O.DB 2014) Wheels, Frames, Helmets, Stages, Cyclist Photos, Sponsorkits, Track Pistes, Accessoires, Mini Jerseys, Equipment Photos, Team Logos, Mini Logos, Race Logos, Staff Logos, Manager Photos, Backgrounds, Temparatures, Country Flags, Scouting Zones, Jerseys, Magazine, Autorun, Newspaper, Faces, Variants, Database, Local, Stats, Tester, Startlists and more GRAPHICAL INPUT (some made one jersey, others made literally hundreds of masterpieces, yet they are all heroes and need to be named) OlegTinkov, Adams55, aidanvn13, Alludha, Alo51, altehacke, anderspcm, ANFreeman, arne_vdb, arnomoto, ataofcom, Barto72, Bavo2810, Bikefreak, Bikex, BoogieBoogie, bottecchia, brianzabike, bwiggins, ByTxT, Cancellara91, canojuancho, Cavendish-Fan, cdelpi, ContaShack, cunego111/1, cyclertom, Dahls, Daniano, Dareun, davidov, Deaddisco, denismenchov08, devnl, dn Son, Dom051, DWB, elfouc, elspartiate, Emenee, ExoiaS, felix_29, Finrod, Francisco, Fus87, Geoffrey, Geraint Thomas, Gilardino, GnrJuul, Grillo, HugoPRT568, hooliganz, home, Il Magnifico, Ivan, Jarotu, JayJunior072, Jaywol, jccavendish, jelle, Jésus de Nazareth, JMURB, jomo023, Jonaldinho59, Katusha-lotto, kev-poccl, KRCFan, kyle, LAge, laidbackmarc, Lance Armstrong 1990, Lampert, lluuiiggii, Maddrengen, Maximka, maxou44, maxteam, mcewen-vélo, Médé33, Messi, michiucf, miggi133, MolokoDrinker, MrContador, n30k, nickwillem, oentje1, Olympus, ozzie68, Pableras, Pantofola di Oro, perot, Petacchi94, Petert87, Pierre80500, pikatchuu2008, Pouhnk, Raben, rasm, raz, Ricardopcm, RicardoRmr, rjc_43, RomainM, roro_352, Sim-eraser, Sinkewitz, Sisse, Speedyfire, Stinooo, Swing59, Syrtaki, tehMalone, the manx express, TheDeksel, Thomazio, Thrige, Tourdedoping, vc_tje_vk94, VDV, Veloman06, Vino, Vlek, Will, Will007 and Zweers. STAGES OlegTinkov, 40leslandes, adiouk555, altehacke, Andrepg, Biggassi, Bikex, Emmea90, frunsi, Georgus, grebiere, HijoDelDiablo, Johan92, Kaimelar, KArt, Koen, Leon40, Maddrengen, Margh Norway, Mark Cavendish, marlak, Médé33, Mlakko, Natalz, Nathounet87, Nils Erik, NTTHRASH, Pellizotti2, Ricardo123, Roturn, Samuel14, SorrowLane, Sporting Nonsense, stardrummer91, Stylus, Svam, tethestar, TheManxMissile, TomC, vangelismoras96, viktorin1988, vmbw3, willxcii and xflyinghighx. |
Autor: | manoxao [ 04 Ago 2014, 23:33 ] |
Assunto da Mensagem: | Re: [PCM14] A.S.O.DB 2014 |
Esta tem a equipa do Louletano? |
Autor: | buba46 [ 04 Ago 2014, 23:35 ] |
Não |
Autor: | nuno estrela [ 05 Ago 2014, 22:17 ] |
o que tem este patch de diferente? |
Autor: | Joao [ 05 Ago 2014, 22:39 ] |
nuno estrela Escreveu: o que tem este patch de diferente? Não é patch é database. E o que tem de diferente de quê? |
Autor: | jotadani [ 07 Ago 2014, 03:23 ] |
Um à parte: as custom teams depois podem entrar no jogo num Modo Carreira mais avançado, substituindo ou entrando com novas equipas? |
Autor: | nuno estrela [ 07 Ago 2014, 22:21 ] |
esta database faz alguma coisa aos equipamentos(quadros.rodas) |
Autor: | buba46 [ 07 Ago 2014, 22:46 ] |
nuno estrela Escreveu: esta database faz alguma coisa aos equipamentos(quadros.rodas) Corrige os nomes |
Autor: | elyk [ 17 Ago 2014, 03:28 ] |
Alguém sabe para quando a db do daily? |
Autor: | padaviro [ 17 Ago 2014, 15:36 ] |
elyk Escreveu: Alguém sabe para quando a db do daily? http://pcmdaily.com/forum/viewthread.ph ... d_id=36526 |
Autor: | elyk [ 17 Ago 2014, 19:09 ] |
padaviro Escreveu: elyk Escreveu: Alguém sabe para quando a db do daily? http://pcmdaily.com/forum/viewthread.ph ... d_id=36526 Obrigadoo |
Página 1 de 1 | Os Horários são TMG [ DST ] |
Powered by phpBB® Forum Software © phpBB Group https://www.phpbb.com/ |
