PCMdaily Expansion Pack V1.0 Download : http://pcmdaily.com/infusions/pro_downl ... p?did=1043The download uploaded to the FTP server(download button) is a torrent file.
An alternative is using a mirror.
It would be appreciated if people who used the torrent can help us seeding(uploading) the file when they're done, to help other downloaders.
Mega mirror:
https://mega.nz/#!y4ZRjDSK!spkHYgn2QtTV ... rDQgElqt-wPlease follow the instructions (below) carefully. We have tried to explain the process as extensive as possible.
Do not forget to download our day one patch afterwards as well, the V1.1(2MB only):
https://mega.nz/#!L8ZBWSyb!bZGnq6zcjGrv ... niioaoiGGsOne does not need to have the V0.5 or V0.8 installed, this download is an all-in.
How to install?It is very important to follow the installation process carefully.
This is the process you will need to make the DB working including the day one update(V1.1)
Using the torrent1. Click download in the download center of the V1. Make sure to have a torrent client installed.
2. Choose download directory when downloading the torrent. It is not important where you put the download, as long as you can find it back.
3. When the download is done, go to the folder where you've installed it(Most likely called: PCMdaily Expansion Pack 2015 V1 and most likely located in your downloads folder)
Proceed to step 4.
Using the MEGA download mirror1. Click download.
2. Go to your downloads and search for the "PCMdaily Expansion Pack 2015 V1.7z". Extract the file with Winrar or 7Zip in a folder of your choice.
3. Now go to the folder where you've extracted the .7z file to. Make sure all of the files ended up in the same folder.
Proceed to step 4.
4. Double click the .exe file (the one with the PCM icon)
5. Now go through the installation.
There will come a very crucial point in which you will have to choose your install path. Please pay a lot of attention.
By default, it will send you to "C:\Program Files\Cyanide\Pro Cycling Manager - Season 2015".
This is however not always the PCM gamefolder.
If you have Steam, this would most likely be "C:\Program Files\Steam\steamapps\common\Pro Cycling Manager 2015".
If you have PCM in another language, or simply installed PCM elsewhere than the default location:
Make sure to change the install directory manually as well. If you are unsure where to install, look in your Program Files folder for "PCM.exe".
You have to install the database in the exact gamefolder where PCM.exe is located. Also make sure you are installing the db in your general PCM folder.
This means *PCM folder*, NOT *PCM folder*\Database.
6. Complete the installation process. Installation can take a while considering it is a huge file.
7. Another crucial thing to do now is to Download the V1.1. It is a very small file but fixed a lot of crucial things and also stats.
It is only 2MB but should be downloaded.
After downloading the V1.1, find the file in downloads, double-click the .exe file and repeat step 5.
Again, make sure to keep the installation folder in mind, you might have to adjust the installation directory.
8. Open PCM 15, go to options and select either "PCMdaily_ExpansionPack_v1_2014NC" or "PCMdaily_ExpansionPack_v1_2015NC" as your database. We recommend using "_2014NC" when you want to play a career and "_2015NC" for playing in Single Race mode.
(The V1.1 is also named V1 to avoid confusion about which file to use)
9. You have completed the installation process of the database. Have fun![/font]
