Data/Hora: 19 Abr 2024, 04:05
Criar Novo Tópico Responder a este Tópico  [ 56 mensagens ]  Ir para página 1, 2, 3, 4  Próximo
MensagemEnviado: 29 Fev 2016, 15:35
A huge pack to improve every aspect of your Pro Cycling Manager 2015 game, with 2016 teams, graphics and races.
For more information about the huge feature list, click here.
General questions thread
Bug report thread (Note that for personal problems with the DB, the support thread suits better)
Stat discussion thread
The file you can download using the Download button is a ZIP-file. Alternatively, you can download the torrent-file here
It would be appreciated if people who used the torrent can help us seeding (uploading) the file when they're done, to help other downloaders.
Please follow the instructions below carefully. We have tried to explain the installation process as extensive as possible.
[center]
Citar:
How to install?
[/center]
Because we got a lot of replies asking for help with the installation, we decided to write an extended installation guide for the installation.
A clean install of Pro Cycling Manager 2015 is recommended before installing this database, to avoid bugs and to save you some space in your HDD. This database is a standalone database one, so you won't need the Expansion Pack to play with it.
1. Download the database from the Downloads section of PCMdaily.
2. Unpack PCMdaily2016DB.zip
3. Go to the folder where you unpacked the file and open the folder Files.
4. Copy the contents of the folder Program Files and paste them in the installation directory of PCM2015. This is usually C:\Program Files\Cyanide\Pro Cycling Manager – Season 2015 or with Steam C:\Program Files\Steam\steamapps\common\Pro Cycling Manager 2015. It could be different when you installed the game in a different language (for example in Dutch the folder will be Pro Cycling Manager – Seizoen 2015) or when you manually changed the directory while installing the game.
You need administrator permission to copy files to this directory. When Windows asks if you want to overwrite existing files, click Yes.
5. Go back to the folder where you unpacked the file and open the folder Files.
6. Copy the contents of the folder Documents and paste them in your Documents folder. When Windows asks if you want to overwrite existing files, click Yes.
7. Now it's time to start the game. On the main page of the game, go to Options (the "gear" at the bottom of the screen), then click Database (the last tab at the top of the popup screen) and select PCMdaily_2016DB_V1 as your database.
8. You have completed the installation process of the database. Have fun!
If you followed this guide, but you’re still having problems with the installation, check the FAQ on the PCM.daily forum. If your problem isn’t listed in there, ask your question in the General questions thread on pcmdaily.com.
Editado pela última vez por Matt17BR em 03 Mai 2016, 12:43, num total de 2 vezes.
This is a pack of variants for a large amount of races which are all in the 2016 Database.
We chose to release these variants as a separate DLC, to reduce the size of the 2016DB installer.
The Variant DLC is an add-on for the PCM.daily 2016 Database, but can also be used with other databases.
[center]
Citar:
How to install?
[/center]
1. Download the Variant DLC from the Downloads section of PCMdaily.
2. Unpack PCMdailyVariantDLC.zip
5. You have completed the installation process of the database. Have fun!
We are proud to announce that we just released the PCM.daily 2016 Database: the most complete database for the 2016 season released so far, if not the most complete ever!
The database contains just as many features as the 2015 Expansion Pack, as well as a lot of quality additions that will deeply enhance your experience while playing Pro Cycling Manager 2015. If you want to take a look at the features in even more detail, click "read more" at the bottom of this news article.
This doesn't mean that the database will make your game unstable, however. During the last month, we have undertaken a beta testing programme and all the bugs that have been reported have been solved. About 20 members of this community have participated in this programme, which helped us solve a lot of known issues and even sped up the process, thanks to some very useful contributions. As you may imagine, we've been working really hard on this database for the past few months, so we hope you'll enjoy it!
The 2016 Database is a standalone database, which means you don't need to have the Expansion Pack installed. In fact, we strongly recommend doing a clean install of PCM2015, before installing the 2016DB. At least 2 game breaking career bugs caused by the old version of the Expansion Pack will be solved doing so, not to mention the amount of GBs you'll save on your HDDs!
You can download the PCM.daily 2016 Database in the download center.
We really hope you enjoy the database. If you have any kind of problems, make sure you check the FAQ thread, and if you don't find a solution, well, any questions can be asked on the forum in the PCM15: PCM.daily Projects section!
MensagemEnviado: 10 Mar 2016, 12:30
Pessoal, nenhum feedback do Pack? Eu ainda não tive oportunidade de experimentar infelizmente.
MensagemEnviado: 10 Mar 2016, 12:48
Está ao nível do habitual, até agora não tenho razão de queixa. :P
MensagemEnviado: 10 Mar 2016, 12:49
Tenho estado a fazer uma carreira com ele, até tirando uma ou outra coisa agora não há muita razão de queixa.
A matrix dos stats está bem feita e até agora tenho tido resultados realistas e tenho consigo fazer coisas interessantes com os ciclistas consoante a forma deles mesmo que não sejam os melhores em prova.
Em termos de provas do que vir por alto (estou no WT por isso não preocupo com muitas provas) vem na sendas de db's anteriores, e tem variantes a dar com pau.
Estava a espera de mais em termos de equipamentos, mas pelo que vejo isso virá em grande parte no próximo update por isso não estou muito preocupado.
Os meus únicos problemas tem sido, o declínio dos ciclistas e neste caso não sei se é do pcm ou mesmo da db porque é a 1º carreira que estou a fazer neste, mas há muitos ciclistas na casa dos 32 anos para cima que começam a descer stats mais rápido do que é normal, por exemplo vou em abril e o Serge Pauwels já desceu 1 stat a tudo, o Farrar já perdeu 3 ou 4 stats em uma data de coisas, e a maior queda que vi foi do Samu que já vai nos 72 a MO quando começa com 76 e 75 a colinas quando começa com 77 e também alguma perda nos stats físicos.
E o Paris Roubaix aqui na minha carreira estar todo bugado, só a simular é que o consegui fazer.
MensagemEnviado: 14 Mar 2016, 18:28
É só a mim que aparece o Rúben Veloso na W52 em vez do Gustavo Veloso? :P
MensagemEnviado: 14 Mar 2016, 22:40
Tenho um problema no PCM 15, instalei-o depois de ter o Windows 10 e tmb instalei a DB do Daily(a desta época) e os gráficos estão uma oops, ou seja só aparece monte e não sei como mudar isso, já fui as definições e mudei mas o jogo não entra... Por favor ajudem-me não quero jogar com monte por todo o lado... Uma altura aconteceu-me o mesmo no 14 quando atualizei para o Windows 8.1, mas já n me lembro como fiz.. :facepalm:
Alguém??
MensagemEnviado: 15 Mar 2016, 01:39
Desinstala tudo e volta a fazer uma instalação do zero. Jogo, depois patch 1.2.0.0 e depois a Daily.
MensagemEnviado: 18 Mar 2016, 00:44
Yah foi esse o problema instalei primeiro a Daily do que o patch.
Obrigado!
MensagemEnviado: 21 Mar 2016, 23:18
Com esta DB as equipas portuguesas já estão actualizadas?
MensagemEnviado: 21 Mar 2016, 23:28
NaP MAGO Escreveu:
Sim.
MensagemEnviado: 22 Mar 2016, 00:13
PeterRyder Escreveu:
NaP MAGO Escreveu:
Sim.
Obrigado.
MensagemEnviado: 23 Mar 2016, 21:40
Não existe link para sacar no torrent?
A minha net é um pouco manhosa e isto leva quase 1 dia a sacar.
MensagemEnviado: 23 Mar 2016, 22:15
NaP MAGO Escreveu:
http://pcmdaily.com/infusions/pro_downl ... p?did=1054
Onde diz 'Optional Mirror'.
