Data/Hora: 23 fev 2019, 16:26
Criar Novo Tópico Responder a este Tópico  [ 23 mensagens ]  Ir para página 1, 2  Próximo
MensagemEnviado: 07 set 2016, 14:51
PCM.daily's Database Team proudly presents the 2016 Expansion Pack for Pro Cycling Manager 2016.
General features
- Real names for divisions, rankings, races and awards
- Countries of Bosnia-Herzegovina, Liechtenstein and Montenegro added
- National teams of Sweden and Ukraine replaced with Czech Republic and Ireland
- 444 real trainers
- 153 real physicians
- 321 real scouts
Cyclists & Teams
- Correct 2016 rosters
- 125 teams (including 6 U23 teams)
- Over 600 additional sponsors
- Over 3500 riders
- Correct characteristics (age, length, weight, country/region of origin) for all riders
- PCM.daily's completely revised stats for all riders
- Revised rider potentials and popularities
- 2011 to 2015 Palmares for almost all races
- Improved realism in terms of rider development and stat progression
- Improved realism in terms of rider regeneration (stats, names, amount of riders from countries)
Graphics
- Correct HD graphics for all teams
- Correct graphics for all custom sponsors (mostly resized)
- NC, WC and/or race leader jerseys for many teams and custom sponsors
- Accessories for all teams
- Many updated national team jerseys
- Correct leader jerseys for a lot of races
- Jacky Durand's Sponsorkits implemented for many races
- Custom newspapers for all races
- New flags replacing Cyanide's default ones
- Rider photos for all riders in WT, PCT and for most of CT
- Logos for almost all races and race categories
Equipment
- Real frames of 58 different brands
- Real wheels of 30 different brands
- Real helmets of 33 different brands
- Real groupsets of 5 different brands (Shimano, SRAM, Campagnolo, FSA, Rotor)
- Correct brands for all teams (correct helmets only in Career/Pro Cyclist Mode)
Races
- 2016 race calendar with correct dates for WT, HC and .1 races
- About 370 races including national championships for 25 countries
- 2016 routes for many races on the calendar
- Realistic teams' lists for all races
- Correct rules and classifications for most races
- Added many National Championships (including ITT)
Other
- Updated translations
Because we got a lot of replies asking for help with the installation, we decided to write an extended installation guide for the installation.
1. Download the database from the Downloads section or with the download link below.
2. Extract all files from PCMdailyExpansionPackV100.7z
3. Open the folder where you extracted it.
3. Double click PCMdailyExpansionPack Setup.exe. When asked for Administrator permissions, click Okay or fill in a password of an administrator to continue.
4. Follow the steps of the installation.
A very crucial point in the installation is the step where you will have to choose the installation directory. This often goes wrong, so here's an extended guide:
By default, this is C:\Program Files\Steam\steamapps\common\Pro Cycling Manager 2016, unless you installed Steam in a different location. If you have PCM in another language, the "Season" part of the default directory has to be translated into your own language (for example in Dutch it will be Pro Cycling Manager - Seizoen 2015). If you are still unsure, take a look at the Frequently Asked Questions (FAQ) thread.
Make sure to install the DB in your general PCM folder, NOT in the subfolder Database.
5. Complete the installation process. Installation can take a while considering it is a huge file.
6. Now it's time to start the game. On the main page of the game, go to Options (the "gear" at the bottom of the screen), then click Database (the last tab at the top of the popup screen) and select PCMdailyExpansionPack_2015NC (to play with the national champions of 2015; recommended for Career or Pro Cyclist Mode) or PCMdailyExpansionPack_2016NC (to play with the national champions of 2016; recommended for One-off Race Mode) as your database.
7. You have completed the installation process of the database. Have fun!
If you followed this guide, but you’re still having problems with the installation, check the Frequently Asked Questions (FAQ) thread on the forum. If your problem isn’t listed in there, ask your question in the General questions thread.
Download the Expansion Pack here (either normal download or torrent)
 Assunto da Mensagem: Re: PCM.Daily Expansion Pack V1
MensagemEnviado: 08 set 2016, 10:37
Já alguém experimentou? Estive o dia todo de ontem só para fazer o download.
MensagemEnviado: 08 set 2016, 11:17
ainda não porque no meu jogo nem se quer da,baixei a base de dados,instalei na pasta do jogo ela foi instalada,mas quando entro no jogo seleciono individual depois pro cyclist ou modo de carreira e aparece um quadrado com a base de dados eu escolho e clico ok depois aparece obrigado por uasr uma base de daod pcm..... e clico em ok e mais nada não avança se quer nem entra pa uma corrida ou carreira,o meu jogo este ano não é originalfoi sacado no site da sidrow,não percebo o porue ja q tb o 2015 tb é da sidrow e dava antes disso todos os jogos do pro cycling são originais mas cansei de o comprar porque é sempre isto todos os anos so problemas por causa das bases de dados e o jogo 2015 então nem joguei sequer base de dados eram mas horriveis muito fracas e se tivesse comprado o jogo estava feito ao bife,bom sera por ser o jogo pirata que a base de dados não esta a funcionar?
MensagemEnviado: 08 set 2016, 15:11
luislopes Escreveu:
Não te poderemos ajudar. viewtopic.php?f=304&t=11454
MensagemEnviado: 10 set 2016, 22:42
Citar:
Update V1.0.1 released
The first update of the Expansion Pack has just been released. It contains fixes for almost all bugs that have been reported in here.
Citar:
For the complete changelog and the download, click here
MensagemEnviado: 12 out 2016, 12:39
Esta db tem variantes? Ou já há algum pack para elas?
MensagemEnviado: 14 out 2016, 14:46
chaves_andre Escreveu:
O Expansion Pack já traz as variantes. Mas ainda há mais packs com variantes, como este por exemplo: http://pcmdaily.com/infusions/pro_downl ... p?did=1090
MensagemEnviado: 28 out 2016, 18:35
Alguém me consegue arranjar só o cdb da base de dados pf ?
MensagemEnviado: 12 nov 2016, 21:20
Faço download da db mas quando vou abrir esta vazia alguem sabe porque? E já fiz o download várias vezes não percebo
MensagemEnviado: 27 mar 2017, 12:25
Para quando uma versão actualizada de 2017? Alguém sabe?
MensagemEnviado: 28 mar 2017, 23:07
rocki97 Escreveu:
Para já ainda não há qualquer novidade. Temos de aguardar.
MensagemEnviado: 29 mar 2017, 06:41
Se tiverem o jogo pela steam, no workshop ha lá uma DB de 2017 para download com 11GB.
MensagemEnviado: 16 mai 2017, 12:46
Parece que a Daily 2017 está para sair brevemente, segundo o Matti. :)
MensagemEnviado: 18 mai 2017, 21:13
Ainda vai sair primeiro o PCM 17 do que a Expansion Pack 2017.
'Futebol não é uma questão de vida e de morte , é muito mais importante do que isso'.
MensagemEnviado: 19 mai 2017, 11:39
Brûno Escreveu:
É verdade que vai sair mais tarde que o habitual, mas um trabalho desta magnitude não é propriamente fácil de fazer. Ainda para mais quando trabalham apenas por carolice, sem nada mais em retorno.
